		Forest Pack => Tutorials => Topic started by: Paul Roberts on February 23, 2015, 09:40:20 am
				Post here your questions and comments about the Animating with Forest Pack (http://www.itoosoft.com/tutorials/tutorial_animation_new.php) tutorial.
				i can`t render start file- it "renders" pure black
 if i switch GI from irradiance to brute force- i can... what is going on...
 edit.
 oh i see- mode was animation... switch to single frame = OK
				Hi for some reason I cannot get the gradient ramp to animate my forests. Noise maps work fine but gradient ramps dont seem to work at all unless I set real world scale size to .001m, at which point it seems to only produce 3 samples (within a 10m x 10m area).  The unit scale of my scene seems fine otherwise.  What am I doing wrong? Any help appreciated.
 As UV coordinates for the map are derived from the surface assigned under the Surfaces (http://docs.itoosoft.com/display/FORESTPACK/Surface) roll-out, I would suggest you to double check the UV mapping of such surface (that it corresponds to applied Map).
				Hi thanks for the response
 Ive made my animated surface area smaller (with appropriate uv) and that seems to help but I still have to set the real world scale to very small sizes to see any effect.
 Im also having another weird related problem: Ive animated my grass blowing in the wind with the gradient map now using the low poly stand-in method but once I get the final frames back from the render farm there seems to be no frame offset in the animation and all the growfx objects are animating at the same frame timeline.
 Could this be because I did not cache them before hand and turn them into meshes?  Currently Im scattering growfx objects directly with growfx wind node to control animation.
 I have a problem when I want to animate object with forest pack.
 I have 5 objects, animated with key frames.. they are moving when I scroll the animation bar.
 When I make a forest object, I add the geometry (my 5 animated objects), I put  in the animation rollout "Follow geometry" and I untap the "animate only at render time" box...
 But nothing happen when I scroll my animation bar from 0 to 100....
 The originals 5 objects are still moving. But the whole population of scattered object with forest doesn't move.
 what's the problem?!
 thanks a lot for your help.
 S.
 is there any solution to this problem im having?  must be something simple:
 "Ive animated my grass blowing in the wind with the gradient map now using the low poly stand-in method but once I get the final frames back from the render farm there seems to be no frame offset in the animation and all the growfx objects are animating at the same frame timeline.
 Could this be because I did not cache them before hand and turn them into meshes?  Currently Im scattering growfx objects directly with growfx wind node to control animation."
 thanks
				Hi!
 Are you using Mental Ray and Forest Pack 5? We've identified a problem in the latest build affecting animation modes while using the mental ray renderer (which is working correctly in FP4). We've been able to fix this problem and it'll be included in the next beta version. If it's urgent please contact support@itoosoft.com and we can send you a patch.
				Hi, can you pass me this file? I am not able to configure it! Thank you
 (http://i65.tinypic.com/168d7rn.jpg)
 Please feel free to check a similar sample scene, where the Animate by Distance to Exclude Area is applied (it allows you to control the animation frames of a distributed item based on its proximity to exclude area(s)). Hope you'll find it helpful.
 Best regadrs,
 Hi.
 Would You share more details? Please check the tutorial (https://www.itoosoft.com/tutorials/animation-new) again and refer to it where You any issues.
				Hi Target, could you be more specific about the issue? Also, which render engine are you using? Animation is not currently supported by Corona, Octane, Fstorm and a few others (though this may change in the future). You can see compatibility information here: https://docs.itoosoft.com/forestpack/requirements
