Author Topic: Autumn Park  (Read 165562 times)
Jose Antonio Dorado
Autumn Park
« on: September 17, 2014, 04:46:47 pm »
Post here your questions and comments about the Autumn Park tutorial.
FC1888
Re: Autumn Park
« Reply #1 on: August 07, 2016, 05:38:50 pm »
At the beginning of the tutorial you mention two ways to add variation. Manually using the mat editor and letting forest pack do it automatically using Optimize Materials, you mentioned you would talk about this later, yet there was no mention of it in the rest of the video
Re: Autumn Park
« Reply #2 on: August 08, 2016, 10:09:42 am »
Thanks for contacting us. This comment refers to the Optimise Materials tool found in the Materials Rollout. It is used to automatically add Forest Colour maps to materials (and a few other optimisations) that can be controlled from the settings found in the materials tab or by opening the material editor and changing them manually. You can see this being used to apply Forest Colour materials to the trees at about the 17.5 minutes mark in the video.
Many thanks!
Tryharder
Re: Autumn Park
« Reply #3 on: October 18, 2017, 03:42:13 pm »
... does not render in 2018.3 with lates vray and forestpro
lightcache never finishes and a have to kill 3ds max process to stop it
any idea ?
same problem in 2017 ... lightcache never finishes
... seems to be a VRay problem ... 3.60.03 ???
ups wrong here ! please move it
problem is with this scene:
AD5_itoosoft_scenes_v2
« Last Edit: October 18, 2017, 04:47:41 pm by Paul Roberts »
Re: Re: Autumn Park
« Reply #4 on: October 18, 2017, 05:45:01 pm »
Thanks for reporting this. We're looking into the likely cause and we'll report back soon.
Cheers,
Re: Autumn Park
« Reply #5 on: October 19, 2017, 10:52:13 am »
Hi, we could isolate the problem in the RC_tiles002 object.
It seems caused by a bug in the Max boolean process, when processing this specific geometry.
Unfortunately this is not something we can fix it, but there is a simple workaround modifying slightly the object:
- Open Style Editor for RC_tiles002.
- Select A2S Generator and modify General->Clipping Area->Expand from 10% to 11%.
We are preparing a modified scene, with this fix applied.
« Last Edit: October 19, 2017, 10:56:04 am by iToo »
Tryharder
Re: Autumn Park
« Reply #6 on: October 19, 2017, 06:20:22 pm »
Hi Paul,
thanks for the info. Works fine now.
Klaus
