Forest Pack => Tutorials => Topic started by: Paul Roberts on April 17, 2018, 02:53:37 pm
Post any questions here about the tutorial "Creating altitude-based ecosystems" (https://www.itoosoft.com/tutorials/creating-altitude-based-ecosystems)
In max 2015 the "Physicalcamera" of the "tutorials" are not seen.
this is the error window message
They are "missing Dlls"
File Name vrender 2018.dlr Class: VrayPhysCamAttributes SuperClass: 0x1130
FileName: phisicalcamera.dlo
Thank You for noticing and informing us about this.
I hope this does not give You trouble following tutorial though.
We've just updated the files for this tutorial. They now use VRayPhysicalCamera instead of the Max Physical Camera (introduced in Max 2016) for compatibility with older versions.
I hope that helps, please let us know if you have any further questions.
Is the fog in the final image made in Photoshop or is there a need trick to do it with Forest Pack?
Lars
Hi there,
Please can you provide us with a tutorial file that we can use for 3ds Max 2014.
Thank you!
Hi Terri,
I've just updated the files, they should now be compatible with 2013+.
All the best,
great, thank you so much
