Author Topic: Creating Libraries  (Read 461576 times)
Creating Libraries
« on: June 02, 2015, 12:54:55 pm »
Post here your questions and comments about the Creating Libraries for Forest Pack tutorial.
« Last Edit: June 02, 2015, 12:59:10 pm by Paul Roberts »
Re: Creating Libraries
« Reply #1 on: June 02, 2015, 03:25:58 pm »
Solid part 2- about preset creation, thank You.
Part1 is missing key part- thumbnails generation.
Plus You have all Your models in one scene- that`s convenient in illustrated case- relatively light grass objects.
More real world case is tress library, easily exceeding gigabytes in size- I wouldn't dare to put all those trees in one file.
My workflow is:
Use hcg asset browser for thumbnail generation- one max file,- one thumbnail.
Then from folder like this:
make library like this:
using script I wrote-
it`s not too user friendly and still have some UI issues, so cant really share it for now..
but iToo team could easily write similar and better during lunch break...
P.S. Can I please ask You custom background color for library browser? I want white, please...
« Last Edit: June 02, 2015, 04:51:49 pm by Rokas »
« Reply #2 on: June 02, 2015, 03:41:12 pm »
Hi Rokas,
Thanks for the extra tips, I'm sure people will find them useful. You're absolutely right about heavy meshes, in this case we would always recommend one model per file. This is mentioned in the large presets section but could have been made more explicit up front.
I'll pass on the request for adjustable background colours.
Many thanks,
Paul.
« Reply #3 on: June 02, 2015, 04:20:22 pm »
I just wanted to follow this up to say that you can also use Forest Pack's import from scene tool to add objects from multiple .max files.  All you need to do is hold down CTRL or SHIFT when selecting the max files and all the objects from those files will be displayed along with the original .max file to which they belong.
Many thanks,
« Reply #4 on: June 02, 2015, 04:26:22 pm »
had I knew this, I would have not written my script...
cheers
« Reply #5 on: June 02, 2015, 04:41:44 pm »
Hi Rokas,
It wasn't obvious from the documentation so I've just added a note.
It looks as though we can add your background colour request though  :)
Many thanks,
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #6 on: June 03, 2015, 11:09:31 am »
Thanks for this tutorial, and the new lawn presets are great !
One thing is confusing me, you say that the path for the presets is
C:\Users\<username>\Documents\Forest Pack\libs
but on my workstation (vista x64) and servers (win 7) it's
C:\Program Files (x86)\Itoo Software\Forest Pack Pro\lib\Presets
« Last Edit: June 03, 2015, 11:16:54 am by Pixelab »
« Reply #7 on: June 03, 2015, 11:16:41 am »
Glad you find the new tutorial useful.
Just to clarify those two paths. C:\Users\<username>\Documents\Forest Pack\libs  is the directory for the User folder that is already found in the library. This is a folder we provide in a standard installation for you to add your own libraries.
On the other hand C:\Program Files (x86)\Itoo Software\Forest Pack Pro\lib\Presets should be the path for the presets that come bundled with Forest Pack. This directory includes all out pre-built libraries.
I hope that helps clear this up.
Many thanks.
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #8 on: June 03, 2015, 11:19:37 am »
Many thanks.
Ok, got it!
We modified the user path to an UNC pointing to a NAS, that's why the user path was unused.
There's no problem using itoo install path to drop the new files, or will they be erased on the next update ? (although they might be included in the next update)
« Reply #9 on: June 03, 2015, 11:25:43 am »
Actually we don't recommend saving any user presets in the user path because this are is wiped with each new update. That said the presets in the tutorial will probably be bundled with a future update, most likely Forest 4.4.
Many thanks,
itooUser
« Reply #10 on: August 03, 2015, 07:27:13 pm »
DEAR SIR
               i am unable lo download the tutorials file  :'(! it is giving me a error ! please look into it or guide me to the tutorial fie
                 Thank you for reading this post
« Reply #11 on: August 03, 2015, 09:25:56 pm »
Hi!
Thanks for reporting this issue, we apologise for any inconvenience. We're looking into the issue and the tutorial files should be  back online soon. I'll update this thread as soon as they are working again.
Many thanks,
« Reply #12 on: August 04, 2015, 03:00:46 pm »
All the tutorial links should now be working. Please let us know if you encounter any problems.
Many thanks,
rkfkalee
« Reply #13 on: August 24, 2015, 07:52:53 am »
I tried to follow the tutorial. I have a Forest lite version.
In the library browser, I couldn't find User's library anywhere.
Also I downlodad the attached file in tutorial page and unpacked it, but I couldn't find the "Presets tutorial" in the library browser.
Where should I unpack the file?
And, when I clicked the "Change preferences" button in library to open "library browser option", there is no "add" button and some buttons are also missing.
Is this a difference between Lite version and Pro version?
On the description of the tutorial, it said the tutorial is for both pro and lite version, so I followed it.
Help me to finish this tutorial.
« Reply #14 on: August 24, 2015, 08:14:28 am »
Thanks for contacting us. I'm afraid that editing and adding user libraries in only supported in the Pro version of the plugin. You can see the full list of differences here.
I apologise if that wasn't clear. I can't find where it says the tutorial is compatible with the lite version, but if you let me know I'll correct it.
Many thanks,
