Toggle navigation
Login
Register
Forest Pack
Tutorials
Modern Barn
« previous
next »
Print
Pages: [
1
2
Author
Topic: Modern Barn (Read 185438 times)
Jose Antonio Dorado
Newbie
Modern Barn
on:
September 17, 2014, 04:48:27 pm »
Post here your questions and comments about the
Modern Barn
tutorial.
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #1 on:
January 27, 2015, 12:55:42 pm »
I cannot let the gradient rampo work well
any suggestion?
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #2 on:
January 27, 2015, 01:12:08 pm »
Hi Alessandro,
Could you give us a few more details. What problem are you experiencing when working with the Gradient Ramp?
Many thanks,
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #3 on:
January 27, 2015, 01:22:55 pm »
http://content.screencast.com/users/Carlocki/folders/Jing/media/de5a18c6-042b-4245-89b4-bf48212149b3/2015-01-27_1319.png
Last Edit: January 27, 2015, 01:37:50 pm by Alessandro Guida
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #4 on:
January 27, 2015, 02:36:38 pm »
new test
to me grass is too rotated anyway all the scattered pyramids have same direction...
I have 2 different problems, rotation angle and + - pattern is not solving.
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #5 on:
January 27, 2015, 02:54:36 pm »
Hi Alessandro.
Seems to be working fine for me:
The only difference I can see between this and your version is that you are using Map Channel 2. I've attached the file for you to take a look at if it helps.
Cheers,
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #6 on:
January 27, 2015, 02:59:40 pm »
Ah! Unless you're not using a surface? Transform by map requires a surface to work correctly in order to extract the correct mapping coordinates.
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #7 on:
January 27, 2015, 03:06:11 pm »
wait Paul
in first test is a surface
second one was a spline test....
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #8 on:
January 27, 2015, 03:13:45 pm »
I re-build up everything. Now it works
thanks
I guees It was a prevoius problems
Now I have to add all the excluded splines but I am sure it would be ok
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #9 on:
January 27, 2015, 03:14:14 pm »
anyway check the online documentation it insiste a lot on channel 2 using.
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #10 on:
January 27, 2015, 03:21:50 pm »
Well there's certainly nothing wrong with using mapping channel 2 (or any other). The only caveat is that if you change the mapping on the surface after adding it to Forest Pack you'll need to ensure you update the surface reference by clicking
in the surfaces rollout.
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #11 on:
January 27, 2015, 03:29:16 pm »
solved thank you.
Paul you are always a nice resource for us..
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #12 on:
January 27, 2015, 04:15:27 pm »
No problem, glad I could help out
Logged
Alessandro Guida
Newbie
Re: Modern Barn
Reply #13 on:
January 27, 2015, 06:28:52 pm »
small resolution impossible to apreciate 2 different grass groups one as main an the other as irregular strips
if I deform the main surface now to have irregularity will I have some further issues?
Logged
ITOOSOFT
Hero Member
Re: Modern Barn
Reply #14 on:
January 27, 2015, 06:53:20 pm »
Looks nice
Should be fine to adjust the main surface, as long as you update in the surface rollout afterwards as described above.
Cheers,
Logged
Print
Pages: [
1
2
« previous
next »
Forest Pack
Tutorials
Modern Barn
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
