Author Topic: Populating Buildlings  (Read 219655 times)
« on: May 11, 2015, 01:08:11 pm »
Post here your questions and comments about the Populating Building Interiors with Forest Pack and RailClone tutorial.
« Last Edit: May 11, 2015, 01:24:34 pm by Paul Roberts »
Ed
Re: Populating Buildlings
« Reply #1 on: March 07, 2016, 10:54:04 am »
Hello Everyone,
I've been following this tutorial with the hope of being able to make the process of furnishing our buildings much faster, but I am encountering a rather weird problem to which I can't find the solution! (I should probably say by now that I have only just started using forest pack...)
I am attaching 3 images to illustrate the problem, which essentially is that all all the objects I add to the list are squeezed vertically. The first image I've attached shows the original box and the squeezing effect when I use it with forest pack. The second and third show this inconvenience when I use the furniture!
Thanks in advance for your time!
« Reply #2 on: March 07, 2016, 11:34:12 am »
It looks as though some of the objects in that scene have been scaled disproportionately. To fix it you'll need to reset the XForm's by following these steps:
1 - Select the Surface floor plate
2 - Open the Utilities Panel.
3 - Select the Reset XForm utility and click Reset Selected.  This will "reset" it's local coordinates / scale and should fix the issue.
4 - Create a new Forest object using the surface.
Many thanks!
Paul.
Hope this helps you, but in case of any further questions or doubts please don't hesitate to contact us. Have a nice day.
Ed
« Reply #3 on: March 07, 2016, 11:38:22 am »
Thank you very much for your reply Paul!
Edmar cortez
« Reply #4 on: November 28, 2020, 08:05:28 pm »
Hi, im a new user of RC and im trying to follow up the Rail clone part, when i export the X parameter an i introduce the units the object replicates on the side and not on top
« Reply #5 on: December 02, 2020, 07:24:47 am »
Please try to setting rotation value to 90:
Hope this helps. If not please attach a maxfile and expanded description of what are You trying to do.
