Author Topic: Railclone Shutter  (Read 76166 times)
NathP
Railclone Shutter
« on: September 13, 2022, 10:35:41 am »
I try to create shutter in RC.
I used an Selector for 3 positions: ID1 Radomly open/ ID2 Open/ ID3 Close.
I created 3 Generators, the first for the structure, with 2 translations Xoffset (3cm for the start, -3cm for the end).
the second for the left Shutter at the start and the last one right shutter in the opposite value, i tried to made all shutter in the same generators but with the mirrors one shutter go in the wall.
I would like to use expression for Xoffset, how can i tell to RC "when i put 10cm in the Xoffset do -10cm for the seconde generator" ?
Re: Railclone Shutter
« Reply #1 on: September 13, 2022, 01:10:40 pm »
You have a couple of options. You could simply multiply the value by -1 to create the inverse, or you could use the Negate Value macro found in Macros > Arithmetic > Negate Value.
I hope that helps,
Paul.
NathP
« Reply #2 on: September 13, 2022, 02:00:30 pm »
It help me very well!
Thank you so much Paul!
Nathan
