Toggle navigation
Login
Register
RailClone
Work in Progress
Partition Glazing Corner Issue
« previous
next »
Print
Pages: [
1
Author
Topic: Partition Glazing Corner Issue (Read 48978 times)
CK4414
Newbie
on:
May 21, 2025, 05:49:55 pm »
I'm working on a partition glazing system featuring dropdown menus. While the setup functions well at a 90-degree angle—maintaining the intended small gap between the glass panes—the issue arises when the angle deviates from 90 degrees. In such cases, the panes either merge or are spaced too far apart. Despite attempting to use conditionals and padding, I haven't achieved the desired consistency.
Could anyone provide guidance on maintaining a uniform distance between the glass panes, regardless of the spline angle? Any insights or suggestions would be greatly appreciated.
I have attached a Top View screenshot of the 90 Degree angle working as intended and the other angle not.
Thank you!
Logged
ITOOSOFT
Hero Member
Re: Partition Glazing Corner Issue
Reply #1 on:
May 22, 2025, 11:02:50 am »
Using an
empty Segment
with a defined small,
Fixed Size
in the
Compose
operator, wired to the
Corner
input of the Generator, does the trick. Please find attached a sample scene that demonstrates this setup. I hope it helps.
Logged
CK4414
Newbie
Reply #2 on:
May 28, 2025, 01:27:52 pm »
Amazing Thank you, i will try and implement!
Logged
Print
Pages: [
1
« previous
next »
RailClone
Work in Progress
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
