Author Topic: Railclone - variation on X-axis Via Transform not Scale - for Wall Cladding  (Read 66669 times)
andregonweb
  • Not typing...
Hi all,
I am trying to achieve the same cladding as attached. The width of each brick must be 59.5cm and the height should be 4cm. So, according to a lot of the tutorials I saw, the x-variation is achieved by scaling the individual segment via it's own random scaling parameter.
My problem though is that I cannot use that technique because the segments need to be very precise in width and height. I need to scatter them randomly 6 to 8 rows down and then maybe a repetition on the 8th. I realize this sounds convoluted but it should be clearer with the images.
I followed along on the tutorial called "QUICK TIP: Creating a strip style parquet floor with RailClone in 3ds Max" (https://youtu.be/qZfXVu17zk4) and it works fine except that the x-start will only ever reference the initial two segments and be perfectly spaced the same 50% apart each time.
Please Help.
Re: Railclone - variation on X-axis Via Transform not Scale - for Wall Cladding
« Reply #1 on: September 22, 2021, 04:47:59 pm »
Thanks for the question. I think in your case you don't need to use the sequence operator. Just wire your full-size segment directly to the Conditional Node's false input, and then the other segment wired directly to the True input can have its X Scale randomised to create the offsets per row.
I hope that helps,
andregonweb
  • Not typing...
« Reply #2 on: September 22, 2021, 05:28:39 pm »
Hi Robert,
Wow!
Thank you very much for the help.
As you can see herewith - the problem has been solved perfectly.
Kind regards!  8) :D
« Reply #3 on: September 22, 2021, 05:30:17 pm »
Excellent - glad we could help out!
Cheers,
andregonweb
  • Not typing...
« Reply #4 on: September 23, 2021, 07:29:09 am »
Me again - hehe
Now that the setup is working - I would like to align the horizontal lines of mutliple railclones with one another (see attached). I'm thinking to export the parameters so I can change them on the fly as I attach them to splines.
I just do not know exactly how to shift the entire array as X-offset just shifts it in a direction leaving me with gaps between te geo and the clipping spline.
Any ideas?
Thanks in advance!
« Reply #5 on: September 24, 2021, 02:07:57 pm »
You can use the Expand property to increase the size of the array beyond the perimeter of the spline before it is clipped, and then use the X and Y offset controls to slide it around.
I hope that helps,
