Author Topic: Railclone Issue  (Read 70439 times)
TonyN
Railclone Issue
« on: September 09, 2022, 03:07:07 pm »
Can someone help figure out where I went wrong? Any help would be appreciated
I have an abutment wall that has A RT/LT padding to extend the outer edges past the line with works. My issue is when I lengthen the line by moving the vertex, I end up with a gap between the main wall and the edges.
The nodding is very complicated maybe I made it more complicated then need be and suggestion?
Re: Railclone Issue
« Reply #1 on: September 09, 2022, 03:21:49 pm »
This would appear to be happening because you are using Scale Mode in some generators with a Default segment with left and right padding. When the segment is scaled, so too is the padding, creating a larger gap. You can change the mode so that padding is unaffected by disabling the Scale Padding option in the Generator's Rules tab.
I hope that helps,
TonyN
Re: Railclone Issue
« Reply #2 on: September 09, 2022, 03:28:36 pm »
Thank you Paul,
That did the trick. Those little things like a button can get you every time. I appreciate your help!!!
You Rock
TonyN
Re: Railclone Issue
« Reply #3 on: September 09, 2022, 06:31:44 pm »
That worked
another question
One more question, Any idea were I went wrong?
If you move the vertex on Y it disassembles, I Think it has something to do with the X offset and the expression.
I got the Z axis fix that was an easy one.
I hope that helps,
