Author Topic: Boundaries  (Read 104880 times)
djibvongenf
Boundaries
« on: September 29, 2024, 08:37:45 pm »
Hi All,
I don't understand why my ref. object, a simple polygone, (pink) goes further (blue) than the area spline (yellow circle).
Boundary edge is checked and no transformation, rotation or scale are checked.
Maybe someone would have a clue
ty
Re: Boundaries
« Reply #1 on: September 30, 2024, 11:03:42 am »
The Edge Boundary Checking mode is not meant to "slice" the geometry, it's removing elements within one item that are "based out of area used for distribution" - t used object(s) should be "divided into Elements". If there are any "overhanging faces" under one element, these will be fully removed or not, depending on whether the element is based inside/outside of the distribution area.
You might consider using our RailClone plug-in, which allows slicing the geometry.
