Author Topic: Lawn being out of scale.  (Read 112452 times)
shanerbs
« on: September 06, 2024, 07:12:44 pm »
Whenever I am using Forest Pack to create a lawn in my project, it is coming in way over scaled and I can not find a setting to lower this without taking away surface area. Any help is appreciated! Is there a way to increase/decrease grass height?
Re: Lawn being out of scale.
« Reply #1 on: September 09, 2024, 08:25:30 am »
It's most likely related to the scale of the object used as a surface. When using any scaled surface, Forest will inherit that scale, which may not be desirable. To fix this, simply reset the Forest scale to 100%. In these situations, I recommend applying the Reset XForm utility to the surface to reset its local coordinates and scale. I hope this helps.
