Author Topic: clone along surface  (Read 85641 times)
EM4616
clone along surface
« on: July 10, 2018, 04:50:38 pm »
hi,
Is there any way I can clone an object according a uneven surface ?
Id like to array a spline along a polygons and these splines have to behave according to the height of the polygon's vertexes
In the attached image, the surface is the green object , witch has different vrtexes heights.
Thank you
Re: clone along surface
« Reply #1 on: July 11, 2018, 11:24:49 am »
For help topics please use Pro board section.
Regarding this issue, it is not possible the way You described.
You can use L1S array with multiple clipping splines.
« Last Edit: July 11, 2018, 11:49:32 am by Rokas »
EM4616
« Reply #2 on: July 11, 2018, 11:41:46 am »
thanks,
I Appreciate if you can explain what the best way  ...
« Reply #3 on: July 11, 2018, 11:50:08 am »
