Author Topic: 3ds max 2011 is hanging when render  (Read 26430 times)
hshfx
« on: September 05, 2010, 04:15:23 pm »
Hello ALL!
Trying to render only some forest but 3ds max 2011 is hanging at first seconds of render.
It's always hanging at "Pre-Processing scene" task. What can I do in this situation?
Thank you!
Re: 3ds max 2011 is hanging when render
« Reply #1 on: September 05, 2010, 06:52:24 pm »
It seems that the Mental Ray shader is not loaded.
What Forest version are you using, 3.3.1 ?
Can you find these files in the Max folder ?
<maxdir>\mentalimages\shaders_autoload\mentalray\include\Fshader3.mi
<maxdir>\mentalimages\shaders_autoload\mentalray\shaders\Fshader3.dll
hshfx
« Reply #2 on: September 06, 2010, 12:16:57 am »
Yes, I'm using Forest Light 3.3.1 and I have files in this folders
« Reply #3 on: September 06, 2010, 10:40:36 am »
Please, make a zip with the content of the folder <maxdir>\mentalimages\shaders_autoload\mentalray, and send it to support@itoosoft.com.
One more thing: can you see the content of the file Shader3.mi opening it with Notepad ?
« Last Edit: September 06, 2010, 10:47:38 am by Itoo »
hshfx
« Reply #4 on: September 07, 2010, 12:01:13 am »
Hello!
I sent a mentalimages folder.rar and this is my FShader3.mi
declare shader
   color "fs_texture3"
      color "texture",
      color "opacity",
      scalar "selfillum",
      boolean "rendmedit",
      shader "base",
      boolean "override",
      color "tint_color1",
      color "tint_color2",
      scalar "tintmin",
      scalar "tintmax",
      integer "tintmode",
      color "tintmap",
      integer "tintmapmode",
      boolean "bbshader",
   gui "gui_fs_texture3"
      control "Global" "Global"
         "uiName" "Forest Texture 3",
         "category" "Itoo Software"
      control "texture" "color"
         "uiName" "Texture",
         "value" .7 .7 .7
      control "opacity" "color"
         "uiName" "Opacity",
         "value" 1 1 1
      control "selfillum" "scalar"
         "uiName" "Self-Illumination",
         "value" .0
      control "rendmedit" "boolean" ()
   version 4
   apply texture, material
end declare
declare shader
   color "fs_shadow3"
      color "vshadow",
      color "hshadow",
      color "shcolor",
      shader "base",
      boolean "bbshader",
   gui "gui_fs_shadow3"
         "uiName" "Forest Shadow 3",
      control "vshadow" "color"
         "uiName" "Vertical Shadow",
         "value" .0 .0 .0
      control "hshadow" "color"
         "uiName" "Horizontal Shadow",
         "value" .0 .0 .0
      control "shcolor" "color"
         "uiName" "Shadow Color",
         "value" .7 .7 .7
   version 3
   apply shadow
end declare
« Last Edit: September 07, 2010, 12:02:51 am by hshfx »
« Reply #5 on: September 07, 2010, 10:19:14 am »
Sorry, i have not received your rar file, probably it was block by some anti-spam filter. I just sent you a personal message (see inbox in your profile) with an alternative email account. If possible, please include the full content of <maxdir>\mentalimages. I want to check some MR configuration files included there.
Although i'm not sure why, it seems that Max cannot find the Mental Ray shader in your configuration.
A shader is based in two files, a definition file (.mi) and a library (.dll).  By the error message, Max cannot even to find the .mi file, although the FShader3.mi seems to be correct. On my side, i only can reproduce this problem deleting this file.
Also it's possible that the configuration file which define the shader folders is missing or corrupt (<maxdir>\mentalimages\rayrc). Have your other computer with Max installed where to copy the content of <maxdir>\mentalimages ?
hshfx
« Reply #6 on: September 07, 2010, 08:00:44 pm »
I really don't know what it was, but when I had reinstall 3ds max in C:\Program Files it began working! Before it 3ds max was installed on another hard drive. Then I had reinstall 3ds max again on drive D:\ and it works again!
Forest Pack working very well! I think 3ds max was not installed correctly in first time...
In any case, thank you for your fast help!!! I'm very sorry for putting you on the wrong way!
I think the topic can be removed
« Last Edit: September 07, 2010, 08:05:29 pm by hshfx »
« Reply #7 on: September 07, 2010, 08:10:06 pm »
Great. I'm glad you solved it  ;)
