Author Topic: adding forest objects to linked objects  (Read 10323 times)
Jorgensen
« on: October 30, 2013, 10:57:01 pm »
I have a building I have linket in from Revit.
When I add forest plants via Custom Edit, I pick a plane in the view (a terrace on the first floor) the plants get added at z=0 :-/
Hmm it seems that forest also ignores faces of a Standard Primitive >Box.
Is it possible for Forest to pick the right z-values?
Re: adding forest objects to linked objects
« Reply #1 on: October 31, 2013, 08:52:38 am »
Custom Edit may work in two modes:
1) Freely: the items can be moved manually to any Z position.
2) Linked with a Surface. You only can move the items on X/Y, the Z value is taken from the Surface.
To work in mode 2), you must assign the terrace in the "Surface" rollout, and turn on Surface->Custom Edit->"Link to Surface". This is the default mode, so probably it doesn't work because you have not any surface assigned in Forest.
Jorgensen
« Reply #2 on: October 31, 2013, 03:03:37 pm »
Hi Carlos
Even when I read your guide, i can't get the trees to stick on a surface :-/
« Reply #3 on: October 31, 2013, 04:45:24 pm »
Please, be sure the normal vectors of the surface are pointing up. If not, apply a "Normal" modifier and reload the Surface in Forest (click the refresh button in the Surfaces rollout).
If it doesn't work, send us a stripped scene to support@itoosoft and we'll check it.
