Author Topic: spline area elevation?  (Read 36542 times)
ldotchops
« on: February 20, 2022, 02:49:30 pm »
Is it possible to use a rectangle spline with curves inthe z axis and have the geometry follow the Z axis? currently it stay at the highest point. i saw other threads but they seemed to not answer with anything i could understand.
Re: spline area elevation?
« Reply #1 on: February 21, 2022, 08:54:03 am »
You can follow the Z position of separate sub splines, but the resultant scatters would be planar areas. For anything non-planar you'd need to use a surface.
Cheers,
