Toggle navigation
Login
Register
Forest Pack
Forest Lite
Edge mode not working with Corona
« previous
next »
Print
Pages: [
1
Author
Topic: Edge mode not working with Corona (Read 64215 times)
domxxe 95
Newbie
on:
March 24, 2022, 03:42:42 pm »
Hello, there is an issue when trying to use Edge mode with corona to scatter grass. ForestEdge is applied in Opacity slot, using spline area, grass made of multiple small mesh models (there is no opacity map, the grass is physical). Forest Pack still doesn't bother going near the edge, and treats it like its Size mode.
. Any sugggestions ? (I'm pretty sure I might have messed some setting by accident)
Logged
ITOOSOFT
Hero Member
Re: Edge mode not working with Corona
Reply #1 on:
March 24, 2022, 03:45:45 pm »
Sorry to hear you have an issue. Is the grass object one from our library or something else? If it's not one of ours, is it a nested Forest object?
Cheers,
Logged
domxxe 95
Newbie
Reply #2 on:
March 24, 2022, 03:53:26 pm »
Yes it's nested object. The grass is made up from 4 different patches, each patch is a single poly object with many mesh elements.
Logged
ITOOSOFT
Hero Member
Reply #3 on:
March 24, 2022, 03:55:53 pm »
Thanks - I'll see if I can reproduce the issue here.
- Paul
Logged
domxxe 95
Newbie
Reply #4 on:
March 24, 2022, 03:59:38 pm »
It does work with other grasses we bought from 3dSky and Nouvelle Mesure Lab. Problem is they already come with FP assembly so its hard to identify what is the difference in their FP object VS one I assembled.
Logged
ITOOSOFT
Hero Member
Reply #5 on:
March 24, 2022, 04:12:36 pm »
Could you share the FP Object with me? It'd make it easier to diagnose. Please feel free to email it to helpdesk@itoosoft.com.
Logged
ITOOSOFT
Hero Member
Reply #6 on:
March 24, 2022, 06:05:24 pm »
Thanks for sending in the file. I've been able to isolate the problem, it would appear that using a Distribution > Density > Rotation value of anything except 0 affects the edge mode feature.
I'll pass this on to the development team, but in the meantime, setting the value to 0 should fix it.
I hope that helps,
Logged
domxxe 95
Newbie
Reply #7 on:
March 24, 2022, 06:11:43 pm »
Thank you so much, yes it did resolve it. Ha, I don't even know how I ended up changing this value since default FP object has this parameter set to 0.
Again, thank you very much for the assist.
Dominykas
Logged
ITOOSOFT
Hero Member
Reply #8 on:
March 24, 2022, 06:19:23 pm »
Great! Glad that helped. Thanks again for reporting it
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Lite
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
