Author Topic: A way to have different wirecolours for each tree in a Forest Pack object?  (Read 4832 times)
Astopia
  • Overmoed komt voor de val.
    • Citypixels - 3D Visualisatie
I want to be able to edit individual trees in one Forest Pack object in post-production with the help of a render element like "VrayWirecolor"
But all the trees in one Forest Pack object seem to have the same Wirecolour.
How can I change this this somehow please?
Thanks!
Pieter
I make illustrations for architecture: Citypixels - 3D Visualisatie
Re: A way to have different wirecolours for each tree in a Forest Pack object?
« Reply #1 on: February 22, 2017, 01:17:36 pm »
Hi Pieter,
Unfortunately it's not possible to generate multiples IDs from a Forest object. Both Max and VRay see it as a single entity, with its own object ID.
As far as i know, we cannot modify vertex colour or other channels from the plugin either. These channels are handled  internally by V-Ray.
But as workaround, you would use Forest Tools to generate stand-alone instances. These instances inherit the ID and wireframe color from the source object. Or you could try Material IDs as outlined in this post: http://forum.itoosoft.com/index.php?topic=3525.msg13780#msg13780
I hope that helps,
