Author Topic: Disappearing trees  (Read 4537 times)
MarcoG
Disappearing trees
« on: September 19, 2015, 10:31:19 am »
I have the same problem as in this post:
http://forum.itoosoft.com/index.php?topic=2371.0
I can see the [F] , edit it, but if i try to detach and reconnect to the surface nothing appears.
Did not happen with all objects, just some, but i have to recreate from scratch.... and my deadline is becoming very close.
It happens with custom objects as well as internal libraries.
- max 2015 sp3, forest 4.4.1, Vray 2.50.01, raiclone 2.50 -
Thanks for all suggestions.
M.
MarcoG
Re: Disappearing trees
« Reply #1 on: September 19, 2015, 10:51:00 am »
I'm sorry, some days ago happened to internal libraries as well, now just with forest objects having custom models inside.
MarcoG
« Reply #2 on: September 19, 2015, 11:39:12 am »
I found some "far" isolated vertices in surfaces showing that problem. Don't know if it helps.
« Reply #3 on: September 19, 2015, 02:04:52 pm »
I guess isolated vertices should not be a problem. Anyway, please send us a simplified scene to support@itoosoft.com and we'll check it.
MarcoG
« Reply #4 on: September 19, 2015, 03:58:09 pm »
Thanks. It's getting me crazy because every time i re-.open the scene i have to redo these parts. Seems that happens only on 2-3 objects. I will send just those parts.
For example in the image attached trees should cover all the surface... not like this. When i created it worked perfectly.
MarcoG
« Reply #5 on: September 19, 2015, 04:00:58 pm »
Strange thing is that i never got this problem when running on max 2013...
MarcoG
« Reply #6 on: September 19, 2015, 04:08:49 pm »
hmm...
I think i've found the problem... that is not a problem...
Sorry, my fault.
Need to sleep...  :(
