Author Topic: Drop Curb_concrete Crub  (Read 16928 times)
Zedish
« on: February 06, 2025, 11:49:25 am »
Hello everyone  :)
I guess the problem I'm going to raise is basic and has been answered elsewhere but I haven't found the answer in the forum.
My problem is that when I change the material of the spline to have a drop curb, the mesh is open, shifted.
Thanks for your answers.
 8)
Re: Drop Curb_concrete Crub
« Reply #1 on: February 06, 2025, 11:59:17 am »
I recommend checking the revised version of the Stone Curb 1 style, which you can download from this closely related post. I hope that helps.
Zedish
« Reply #2 on: February 06, 2025, 12:14:40 pm »
Oh thanks Michal  ;) ;)
Do you have a link to a tutorial I can follow to add it cleanly to the RailClone Library please?
« Reply #3 on: February 06, 2025, 12:20:20 pm »
You're welcome. Feel free to check this section of our documentation to see how to easily add selected RailClone object(s) from a scene to a library in just a few clicks. I hope that helps.
Zedish
« Reply #4 on: February 06, 2025, 03:32:07 pm »
Ok thank you very much for your help, it's very kind  :)
I'm having the same problem with the Sidewalk, is there also a version of the style that works?
« Reply #5 on: February 07, 2025, 09:15:07 am »
Try switching the X Corner > Bevel Mode in the Paving Generator from 'None' to 'Reset,' 'Extend,' or 'Symmetric' to see if that helps.
Zedish
« Reply #6 on: February 10, 2025, 11:31:05 am »
Hello, thank you very much for your support, but it doesn't work any better  :-[ . The geometry overlaps irrationally. It's amazing how complex things can get with Railclone but you can't produce a simple, correct kerb... :-\
« Reply #7 on: February 10, 2025, 12:17:27 pm »
From the screenshot you provided, I can see two vertices that are very close to each other, which may be preventing the geometry from fitting correctly. Feel free to send us your scene, and we’ll check it on our end. Thanks in advance.
Zedish
« Reply #8 on: February 10, 2025, 12:43:11 pm »
Hi Michal, I've attached the file.
« Reply #9 on: February 11, 2025, 09:33:08 am »
Attached is a revised version of your scene (250211_RC_SidewalkProblem_ITOOSOFT.max), edited by my colleague Paul - this version uses a different style setup to handle these corners.
Zedish
« Reply #10 on: February 11, 2025, 10:09:40 am »
you're doing a great job thank you!  8)
