Author Topic: Display -> Viewport not working correctly  (Read 15020 times)
SR1351
« on: March 18, 2017, 09:44:02 pm »
I have many scattered objects of grass. For some reason it doesn't display correctly I cannot reduce the amount of objects in the viewport no matter what I try, "Max Items" I put all the way down to 5 and it still shows them all.  I noticed also if I up the destination units from 70 to 100 all objects in viewport disappear. Everything renders fine though.
Re: Display -> Viewport not working correctly
« Reply #1 on: March 20, 2017, 12:45:40 pm »
Are you adjusting the Display - Viewport - Max items value (there is a similar value under Display - Render - Max items)? Would you mind to specify your configuration (which 3ds max / Forest Pack / renderer releases are you using)? Thanks in advance.
SR1351
« Reply #2 on: March 20, 2017, 08:04:37 pm »
I'm adjusting under display - viewport - max items.  using Max 2017 & FP 5.2.0
« Reply #3 on: March 21, 2017, 10:28:23 am »
Upon our internal tests all works as supposed on mentioned configuration. Would you mind to send us your scene (ideally simplified and containing just problematic object(s)) to check it here? Thanks in advance.
SR1351
« Reply #4 on: March 21, 2017, 06:49:43 pm »
Yes I'll simplify the scene and send it
steve3duk
« Reply #5 on: January 11, 2021, 03:28:20 pm »
I'm having exactly the same problem in 2021 so I'm guessing it is meant to be this way or was never fixed. Any help appreciated.
zules
« Reply #6 on: April 08, 2024, 02:31:38 pm »
Up !
Same problem here...
« Reply #7 on: April 09, 2024, 09:29:37 am »
If possible, feel free to send us your scene - preferably simplified and containing only the problematic object(s) - ideally, if you can reproduce it on a minimal scene, it would be greatly appreciated. Thanks in advance.
