Author Topic: Replace forest color map / instanciate  (Read 3222 times)
in3des
« on: August 08, 2016, 01:08:04 pm »
Hi guys,
Please advise how you deal with forest color map after converting forest to instances.
I'm trying to find best solution for that. What is the best/easiest way to get similar result as forest color map.
The problem is render-farm does not have Forest Pro/Lite installed, and it is not possible to install.
Thanks for any help.
in3des
Re: Replace forest color map / instanciate
« Reply #1 on: August 08, 2016, 01:58:43 pm »
for the moment I do just - delete forest color map and keep just main texture map for diffuse
as I didn't find any easy color variation solution.
« Reply #2 on: August 08, 2016, 03:43:53 pm »
Well, at present the Forest Color map only works with objects that are a part of a Forest Pack object.
Depending on render engine used, you might find useful V-Ray's VRayMultiSubTex map - using the Random by Node handle mode / Corona's CoronaMultiTex map - the Instance mode or any third-party plug-ins for similar purposes like CG Source's MultiTexture map (free) or VizPark's Crossmap (paid).
Hope that helps.
in3des
« Reply #3 on: August 08, 2016, 05:09:41 pm »
Oh, VRayMultiSubTex map looks very similar to forest color map.
I will give it a try.
Thanks a lot!
