Author Topic: After using Vertical grasses won't reset  (Read 5913 times)
Sketchrender
« on: October 17, 2025, 02:17:19 pm »
Afternoon.
After using the vertical grasses, if I want use a normal flat area, it keeps going to vertical not flat.
How do you reset this?
Thank you
Phil
Re: After using Vertical grasses won't reset
« Reply #1 on: October 17, 2025, 02:28:49 pm »
Hi Phil,
Please double-check the orientation of the Forest object — realigning it to the world axes should fix the issue. If that doesn’t resolve it, could you please send us a simplified version of your scene so we can analyze it further? Thank you in advance for any additional comments on this issue that you can share with us or our user community, in case other users encounter similar troubles.
