Author Topic: Save selected issue  (Read 3290 times)
IT1371
Save selected issue
« on: November 12, 2014, 12:37:57 pm »
I opened some scene and recreated the forest object in it, added some parameters and basically did no overkill.
Anyway, I really liked the result so I Save selected all the Forest objects and surfaces to a separate file to use in an other project.
If I open that new file, forest behaves differently - if I hit render its unrecognizable - although all parameters are the same.
I did not change scale or units or anything.
Just Save Selected and open.
All objects are from presets.
Why?
Re: Save selected issue
« Reply #1 on: November 13, 2014, 11:03:14 am »
The Save Selected function could have problems to access hidden / frozen objects. If you want to save it this way, please remove any restrictions from these object(s) / layer(s) or move them to any "unrestricted" layer.
Anyway, we recommend you to proceed a Merge into a new scene with Display Influences and Select Influences selected in Merge window. That will bring to your new scene all objects needed to rebuild the Forest object.
Kind regards,
IT1371
« Reply #2 on: November 16, 2014, 09:17:21 am »
Kind regards,
Well Its still works weird. I don't know what exactly it depends on, but its a 50/50 chance every time.
Thanks for the help :)
