Author Topic: Forest Library, Gamma & Materials  (Read 3209 times)
NT3334
  • Guest
« on: July 08, 2019, 06:31:39 pm »
When using the library presets they render very dark. To solve this I copy the multi material from forest to the Slate Editor and import the textures with a gamma of 1.
I don't understand why this is because my settings should allow the library items to render correctly - my settings for 3ds Max 2016 and VRay Next GPU 4.2 are below;
Re: Forest Library, Gamma & Materials
« Reply #1 on: July 09, 2019, 07:57:47 am »
We can take a look in Your whole scene setup if You could attach or share Your archived scene file.
NT3334
  • Guest
« Reply #2 on: July 09, 2019, 11:52:55 am »
Below are two renders using the free shader ball supplied by BBB3.
One shows it with the default FP settings with a gamma of 2.2 (darker). The other is with the bitmaps imported at a gamma of 1.0 (brighter).
I will PM you with the link to the archive file.
« Reply #3 on: July 09, 2019, 03:20:26 pm »
Brighter version does not look natural for me. Anyway Gamma settings for diffuse maps should be left at 2.2 for our library assets.
