Author Topic: Light String  (Read 13537 times)
lingrenddd
Light String
« on: March 25, 2025, 06:48:46 pm »
Light string, how can I make the lights and the ends of the wires have some distance? The lights should not be generated at both ends. Attached is the max file. Thank you!
Re: Light String
« Reply #1 on: March 26, 2025, 08:47:10 am »
In this particular case, since the number of lights on these splines is equal, you can use the Geom ID > Sequence mode and disable the first and last items. However, for this purpose, the RailClone plug-in would be a more effective solution, as it allows you to easily define the use of only the Corner Input. Please find attached modified versions of your scene. I hope this helps.
lingrenddd
Re: Light String
« Reply #2 on: March 28, 2025, 01:22:04 pm »
But my basic object is a group of lamp models and light objects. Can RC pick them up?
Re: Light String
« Reply #3 on: April 01, 2025, 02:37:58 pm »
Apologies for the delayed response. Yes, the RailClone plug-in can handle these groups, including light objects. Please feel free to review the previously attached scene 250326_light_RC_ITOOSOFT.max.
