Author Topic: bend by object multple objects?  (Read 2809 times)
ldotchops
« on: February 23, 2022, 12:00:15 am »
Is there a way to use more than one object for bend by object effect? making a second effect doesn't work. Also is it just from the pivot, not the surface itself? I wanted to use a long rectangle that sweeps across in a line.
It also doesn't seem to work very well with in UV mode on bent surfaces. they bend in strange ways and the falloff seems to fail.
« Last Edit: February 23, 2022, 12:06:21 am by ldotchops »
Re: bend by object multple objects?
« Reply #1 on: February 24, 2022, 11:09:39 am »
I'm afraid, that multiple objects aren't supported by this effect, which is using just the positions of the object (its Pivot Point) as you‘ve pointed out. Instead, creating a Spline Excluce Area(s) and using the Bend by exclude area effect should do the trick ;)
