Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Boundary checking- Edge mode on (partially) stacked surface?
« previous
next »
Print
Pages: [
1
Author
Topic: Boundary checking- Edge mode on (partially) stacked surface? (Read 7623 times)
ritoo
Jr. Member
on:
January 20, 2025, 02:53:10 pm »
Is there a way to make the subject work?
Logged
ITOOSOFT
Hero Member
Re: Boundary checking- Edge mode on (partially) stacked surface?
Reply #1 on:
January 20, 2025, 03:25:06 pm »
Could you please specify the versions of your software configuration, including 3ds Max, the renderer, and Forest Pack? Additionally, do you manage these planes as separate objects or as a single object? Thank you in advance.
Logged
ritoo
Jr. Member
Reply #2 on:
January 20, 2025, 04:03:57 pm »
Latest FP (common grass 01 (large) preset is shown on the picture above) , any vray - gpu\cpu\6\7, max 23\25. It could be a single surface or multiple ones (via forest set or straight) - edge cutting won't work on partially stacked geo. Can't you reproduce the issue?
Last Edit: January 20, 2025, 04:07:05 pm by ritoo
Logged
ritoo
Jr. Member
Reply #3 on:
January 21, 2025, 08:47:02 am »
The problem is not stacked surface per se but UV mode which does not support edge cutting (even on not stacked surfaces)
I need UV mode instead of XY because its not being scattered in overlapping areas
P.S. BTW I noticed Surf.Mat.ID in Areas rollout feature works only in XY mode
P.P.S. The only workaround in my situation that I found is using
multiple
surfaces in
XY
mode.
So my humble request is please make edge work in UV mode.
Last Edit: January 21, 2025, 09:06:54 am by ritoo
Logged
ITOOSOFT
Hero Member
Reply #4 on:
January 21, 2025, 09:48:53 am »
Thank you for your prompt reply. As you mentioned, the Edge Boundary Checking mode does have some limitations - we’ll look into ways to improve it for these scenarios.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
