Author Topic: Distribute a Forest Pack from an existing Forestpack?  (Read 4211 times)
darthmurda
    • MichaelJohnsonCg@gmail.com
« on: September 18, 2018, 08:04:11 pm »
Forgive me if this is obvious but, is there a way if you already have a forest pack system for trees, then wanted to add shrubs around the base of the trees using the tree forestpack as a distribution area? So basically  I want to spawn shrubs around an existing forest pack system using the existing forestpack as the distribution area.
Re: Distribute a Forest Pack from an existing Forestpack?
« Reply #1 on: September 19, 2018, 01:36:44 pm »
Thanks for question. Let's do that.
First we have trees already scattered:
Let's add default distribution of bushes:
Then add ForestPack Trees as Exclude Area:
Then adjust Fallof Parameters: Enable Density and add some distance for it:
What is left is inverting Density Area Falloff Curve:
That is it. Hope that helps.
