Author Topic: Cluster gaps  (Read 3385 times)
ritoo
Cluster gaps
« on: January 15, 2022, 09:00:10 am »
Hello, would it be possible to implement gap between clusters option?
RealViz
    • RealViz
Re: Cluster gaps
« Reply #1 on: January 17, 2022, 07:02:06 am »
Just add a blank geometry with a specific color.
ritoo
Re: Cluster gaps
« Reply #2 on: January 17, 2022, 08:33:53 am »
but I'm not talking about some localized empty areas (clusters) but rather collision setting for a cluster, as if  cluster was ONE object.
« Last Edit: January 17, 2022, 11:41:03 am by ritoo »
RealViz
    • RealViz
Re: Cluster gaps
« Reply #3 on: January 17, 2022, 10:40:22 am »
Oh, sorry. Now I understand. Interesting feature. Now the only way to do it would be to create a bitmap/procedural map.
ritoo
Re: Cluster gaps
« Reply #4 on: January 17, 2022, 01:03:23 pm »
how would you set it up procedually (with noise map for instance)?
Re: Cluster gaps
« Reply #5 on: January 17, 2022, 02:32:05 pm »
I'm afraid the clustering algorithm we use doesn't allow us to add a gap around each cluster. As RealViz mentions, you might be able to do something with a custom map in combination with Forest Pack's Distribution > Diversity > Match Color Id on map feature. Maybe someone who is clever with substance or OSL could create a map that would work to create this effect.
Paul.
RealViz
    • RealViz
Re: Cluster gaps
« Reply #6 on: January 19, 2022, 08:33:57 am »
Perhaps a simple Noise 3D might suffice.
Edit: Or combination with cellular.
« Last Edit: January 19, 2022, 08:36:09 am by RealViz »
