Author Topic: forest color manual id settings  (Read 4827 times)
CO2263
« on: September 20, 2013, 12:28:12 pm »
I'm scattering cars using forest and using forest color map to have random colors
but...
is it possible to manually adjust IDs so I can control color of each particular car
Re: forest color manual id settings
« Reply #1 on: September 20, 2013, 02:50:04 pm »
Not using Forest Color, because colors are always random, but you would use different cars:
1) Create several items in the geometry list, all of them may use the same Custom Object.
2) Add different materials to Geometry->Material, changing the color in each one.
3) Change the model assigned to each item, using Tree Editor->Properties.
Obviously, this procedure works only in Custom Edit mode.
CO2263
« Reply #2 on: September 20, 2013, 03:09:36 pm »
that was the thing I was trying to avoid - creating more materials and more geometry instances
hope its possible to implement in the future to have control over IDs
my walkaround - create a raw of cars and select the colors I need, then copy those cars if needed
« Last Edit: September 20, 2013, 03:19:25 pm by CO2263 »
