Author Topic: Copy ForestIvy  (Read 101387 times)
FC2603
Copy ForestIvy
« on: February 11, 2025, 07:59:26 pm »
Is it possible to make a copy of a ForestIvy object? When I do the copy has no geometry.
edit: Sorry, just realised there's a ForestIvy board that I should have posted this in.
« Last Edit: February 11, 2025, 08:07:32 pm by FC2603 »
Re: Copy ForestIvy
« Reply #1 on: February 12, 2025, 09:04:23 am »
Copying ForestIvy objects depends on the setup. If you're using the Grow without Baseline option, you can simply copy the object and place it where needed. However, if a baseline is used, you should first Export it, move it to the desired location, and then Import it again into the copied ForestIvy object. If you're using Surface Object(s), keep in mind that they also need to be copied separately, as they are not embedded within the ForestIvy object.
FC2603
Re: Copy ForestIvy
« Reply #2 on: February 12, 2025, 09:39:26 am »
Understood, thanks.
