Author Topic: Problems converting to editable mesh  (Read 4840 times)
Robin Arnecke
« on: August 01, 2017, 06:27:29 pm »
i have a problem converting a forest object into an editable mesh object. Once i try this i get an empty editable mesh object with no faces at all.
Just doing it over right mouse button menu, also tried  it over the modifier stack, same problem.
I`m using the newest ForestPackPro 5.4 version with 3dsmax 2016.
Any help on this would be great.
Robin
Re: Problems converting to editable mesh
« Reply #1 on: August 01, 2017, 07:24:08 pm »
Are you displaying forest object as mesh before converting to editable mesh? You should.
Robin Arnecke
« Reply #2 on: August 01, 2017, 10:47:59 pm »
Hi Rokas,
thanks man...that solved the issue i had.
Robin
