Author Topic: Corona Distance for density?  (Read 26064 times)
Lupaz
« on: June 26, 2025, 09:34:03 pm »
I need to reduce the density of a type of plant (mondo grass) based on the distance from a path.
I thought of using corona distance as a map but it seems Forest doesn't recognize gray areas if I use it for distribution.
Is there a way to plug it in somewhere else for this purpose? If not, is there a way to reduce the density based on the distance to an object?
Thank you
Lupaz
Re: Corona Distance for density?
« Reply #1 on: June 26, 2025, 09:39:31 pm »
I found this video to solve it.
But I'm still interested in knowing if this is possible with corona distance. thanks.
https://www.youtube.com/watch?v=h2Ier_n1Oe8
« Reply #2 on: June 27, 2025, 12:14:20 pm »
First, let me mention that using the CoronaDistance map as a Distribution Map is possible. Just make sure that the Forest object is placed at the world origin to ensure it works correctly. To simulate varying density you can combine multiple maps. In the attached sample scene (250627_CoronaDistanceSampleScene_ITOOSOFT.max), I’ve used a simple Noise map to demonstrate this approach. I hope this helps.
Lupaz
« Reply #3 on: June 27, 2025, 05:29:30 pm »
Thank you very much for that example.
« Last Edit: June 27, 2025, 06:02:48 pm by Lupaz »
Lupaz
« Reply #4 on: July 03, 2025, 04:06:29 pm »
Not sure if this was suggested before, but it would be great if Forest pack could use gradients and not just black/white for distribution and density.
« Reply #5 on: July 08, 2025, 01:11:26 pm »
Added for next updates. Thanks for your suggestion !
