Author Topic: Corona Distributed Rendering  (Read 3949 times)
RS3154
« on: September 21, 2018, 03:23:27 pm »
Hello all,
I'm running a farm with 9 pcs and 2 forest pro licences activated. I'm trying to use Corona's Distributed Rendering, but the renderings are not getting out fine, as you can see in the image below.
http://prntscr.com/kx2c9g
My question is: having 2 licences, how many machines can I use in Corona Distributed Rendering?
many thanks,
Re: Corona Distributed Rendering
« Reply #1 on: September 22, 2018, 09:36:26 am »
Hi, when Forest is running in a render node, it doesn't require any license.
The setup program includes a specific option for render nodes, but it's basically a standard installation without specifying any license mode.
Usually these problems are caused because the plugin is not installed correctly in the render nodes, or cannot run for some reason.
Does it happen only with Distributed Rendering, or also with Backburner ?
Have you tried rendering a basic model (as a scattered teapot) ? Just to be sure it's not a missing texture issue...
