Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Corona Render: Forest Color Map with Distribution Map bug
« previous
next »
Print
Pages: [
1
Author
Topic: Corona Render: Forest Color Map with Distribution Map bug (Read 4935 times)
Tengiz
Newbie
on:
May 19, 2014, 05:19:42 am »
jpg01 - ForestColor Map with Distribution Map (set "full")
jpg02 - ForestColor Map with Distribution Map (set "other" and change my texture)
jpg03 - ForestColor Map with Distribution Map with collision (set "other" and change my texture)
I use my texture in Distribution Map and i use ForestColor Map. I have bug on render if i use texture in distribution map larger than 100x100 pixels.
Last Edit: May 19, 2014, 05:26:26 am by Tengiz
Logged
Tengiz
Newbie
Re: Corona Render: Forest Color Map with Distribution Map bug
Reply #1 on:
May 19, 2014, 05:22:46 am »
Images
Logged
Administrator
Hero Member
Reply #2 on:
May 19, 2014, 09:44:25 am »
Please, try setting the texture in "Distribution->Map", instead in "Bitmap". That seems to solve the problem.
I added the bug to the to-do list.
Logged
Tengiz
Newbie
Reply #3 on:
May 19, 2014, 05:51:56 pm »
It works if I set density x=100. If I change the density more than 170, the bug appears again.
Logged
Administrator
Hero Member
Reply #4 on:
May 20, 2014, 10:09:27 am »
Yes, you are right. It's a strange issue, because happens only with Corona Render.
We'll investigate the problem, although unfortunately there is not other workaround. I apologize by the inconveniences.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
