Author Topic: some X-offset when custom edit mode along spline  (Read 5255 times)
in3des
« on: February 18, 2014, 02:33:43 pm »
hi
found some bug maybe...
or maybe its just my scene issue so pelase help
when I plant bushes along spline with 0.3m spacing it shifts to the right a bit.
please find attached screenshot and scene
thx
in3des
Re: some X-offset when custom edit mode along spline
« Reply #1 on: February 18, 2014, 02:37:00 pm »
PS
attaching to a new spline doesn't help
same with surface
« Reply #2 on: February 18, 2014, 03:46:25 pm »
The Forest object has a rotation component which is affecting the item's position over the surface. Please, try this:
1) Select the Forest object, right click->Rotate.
2) Press F12 to show the transform values.
3) Set Rotation to 0,0,0.
4) Click Creation Tools->Create to regenerate the items.
Alternatively you may recreate the Forest object.
in3des
« Reply #3 on: February 18, 2014, 03:56:31 pm »
thanks a lot!
very simple solution =)
