Author Topic: merging forest objects from another scene  (Read 3373 times)
grue
« on: February 12, 2020, 09:51:50 pm »
is it possible to merge via File > Import > Merge in 3ds max 2020?  forest objects.
i have merged all the scatter items, merged the surfaces, merged the splines.  but when i tried to merge 1 of the forest objects, max crashed immediately.
thanks.
Re: merging forest objects from another scene
« Reply #1 on: February 13, 2020, 07:24:53 am »
It should be possible. Would You please send us Your file and we will check it.
grue
« Reply #2 on: February 14, 2020, 09:06:40 pm »
eek.  can't send the file i was working with it's well over 1.5GB and we have an NDA with the client.  i will see if i can reproduce with another file.
grue
« Reply #3 on: February 21, 2020, 11:19:59 pm »
hello, i've just emailed the archive file where i'm tring to merge from.
EDIT: it didn't seem clear in terms of creating my own library item whether or not i could create a library file that contained the things in the file i sent.
1. forest object: small 6" radius circle with 6 individual grass blades (each with different colors, no bitmaps)
2. forest object: larger 1ft radius circle with 6 other individual grass blades (each with different colors, no bitmaps)
3. one large forest object with the two smaller forest objects as items
that way i could not only adjust the one large object, but i could adjust the radius of the smaller circles or adjust their scales etc... so i'm using 2 small forest objects to create one big one.
thanks
« Last Edit: February 21, 2020, 11:44:28 pm by grue »
