Author Topic: exclude objects  (Read 5776 times)
ES1947
exclude objects
« on: December 04, 2013, 10:19:40 pm »
hi
i'm working on a masterplan where I would like add some plants, but exclude the roads.
i select the ground then, under areas I add the road.
it work fine, except from the exclude area seems to be offset.
can this somehow be adjust? in both x and y?
otherwise, it's a very useful plugin!
thanks
ES1947
Re: exclude objects
« Reply #1 on: December 04, 2013, 10:32:39 pm »
it works very well, but there are some glitches :-/
I don't know what I do wrong :-/
Re: exclude objects
« Reply #2 on: December 05, 2013, 05:40:31 am »
Do you use exclude by Object or Spline ?
The exclude by object is based in a bitmap mask which Forest builds internally. This mode is less precise than a spline, specially using large objects. I mean, it may work fine for a house, but worse for a large road. Although you can increase the resolution of the bitmap (see the area parameters), in this case i suggest to use an area spline. It's much faster and precise.
Besides that, try setting Area->Boundary Checking to Size. That may help.
ES1947
Re: exclude objects
« Reply #3 on: December 05, 2013, 08:26:41 am »
Hi Carlos
drwaing splines is sure not faster, but it seems necessary.
i have added both the road, and an extra spline to remove the issues. it seems that trees also enter inside the spline.
boundery checking is grayed out.
i have attached a screenshot. the spline is the thin red line. i have marked the issues with the blue line.
it is a very large model, can this cause the problems?
Re: exclude objects
« Reply #4 on: December 05, 2013, 08:49:50 am »
Sorry, i mean that area spline works internally faster, but obviously it requires some extra work.
I forgot to mention it: Boundary Checking is enabled only for Include/Surface areas, but it affects to all Exclude areas.
The size of the model theorically should not be a problem. Please, be sure the tree's pivot is centered. If it doesn't work, send us a stripped scene to support@itoosoft.com.
Re: exclude objects
« Reply #5 on: December 05, 2013, 10:19:50 am »
Thanks for the scene. Problem was the Transform->Translation (20%). It's applied after computing the item's position, so may affect the area's boundary.
A lower value should fix the problem.
ES1947
Re: exclude objects
« Reply #6 on: December 06, 2013, 09:30:34 am »
Hi Carlos
sorry my fault, I'm still learning, but i'm glad it was easy to fix :-)
once again thanks for your fast and efficient support!
thanks
