Author Topic: Disappearing leaves on render nodes  (Read 7267 times)
Macker
« on: July 24, 2017, 10:12:44 am »
We have just updated our systems to Max 2018, Forest Pro 5.4.0 and VRay 3.6 and have quite an issue with rendering on files that previously worked fine.
Workstations are rendering just fine, but when the render nodes kick in using distributed rendering all of the leaves on the trees disappear; though the trunks/branches/twigs still render.
All mapping appears to be fine, and the nodes are on the same versions of the software.
Re: Disappearing leaves on render nodes
« Reply #1 on: July 24, 2017, 10:26:14 am »
Please, see this post.
It seems the same problem, which theorically is fixed in V-Ray 3.60.02.
Macker
« Reply #2 on: July 24, 2017, 11:42:54 am »
Yes, the latest version fixed it thankfully.
Cheers
leonardo.afanador
« Reply #3 on: July 25, 2017, 03:59:02 pm »
I'm facing the same problem.
https://vimeo.com/226904748
with the previous version of vray was worst, the latest vray version worked a bit better but didn't fix the whole problem.
pass:  itoo
« Reply #4 on: July 25, 2017, 05:08:15 pm »
Regarding this issue, please report directly to ChaosGroup. Only they can fix it.
Thanks.
leonardo.afanador
« Reply #5 on: July 25, 2017, 05:42:17 pm »
thank you.
I've already wrote on their forum.
leonardo.afanador
« Reply #6 on: July 25, 2017, 08:07:52 pm »
answer from chaosgroup forum:
There will be a 3.60.03 a bit later this week that definitively fixes the issue (it is also already fixed in the stable 3.6 builds on the nightly builds server). Sorry for the troubles - this was because of some optimization that we tried to do, but it doesn't work correctly for Forest Pack.
