Author Topic: Drive Distribution map from Gradient map (seen at Total Chaos)  (Read 5367 times)
eqko
While attending Paul's MasterClass on Forest, he mentioned and showed a small bit about how
a gradient map by default wouldn't work as a distribution map (because of the inherent black/white where a pixel is either black or white)
and distributes objects based on that.
He then proceded showing how to use a gradient ramp map to drive the distribution of objects that distribute less and less as the gradient changes from black to white.
I can't for the life of me remember how he did it though.
I wrote a lot of what he said down, but THAT I failed to. And now i need it...
my problem in this case, I have a faced on which I want to distribute leds using forest, that dither out outwards to less distribution
(for which I hope to use the gradient map)
The center is a full distribution, going outwards distribution lessens.
does that make sense ?
any help would be appreciated.
Re: Drive Distribution map from Gradient map (seen at Total Chaos)
« Reply #1 on: May 28, 2018, 08:42:00 pm »
I am not sure what workflow Paul has demonstrated, I will share mine:
You can modify distribution by adding a mask to "distribution".bmp map in composite map:
Click dense.bmp once window popups with many distribution maps- drag "distribution".bmp to Your slate material editor and adjust further:
eqko
« Reply #2 on: May 30, 2018, 08:48:50 am »
Hi ROkas, while certainly an applicable method. I would need the fallof of the density to be much larger ... over a much bigger range.
After some extra searching, I think this post & method is what Paul was referring to, which unfortunately is Forest 6
I'll see if I can get away with your method for now though.
Thanks a lot.
« Reply #3 on: May 30, 2018, 08:58:43 am »
I hope You get effect You are after.
If You have any issues please get back and we will try to help You out.
« Reply #4 on: May 30, 2018, 11:37:44 am »
It was indeed the Forest Effect based approach I mentioned (not the particles). The effect is included in Forest 6 only I'm afraid because it needs map support. There are a couple of other options too though. In this thread, you can find some extra info including a Substance map that will turn a greyscale map into a speckle map that can be used with Forest Pack's existing distribution methods.
https://forum.itoosoft.com/forest-pro-(*)/falloff-density-from-bitmap/msg15345/#msg15345
I hope that helps, please let us know if you have any further questions.
All the best,
eqko
« Reply #5 on: May 30, 2018, 12:38:14 pm »
The Substance map works like a charm and is good enough for what I need. Thanks Paul.
Looking forward to Forest 6 and all it's added effects & features.
