Author Topic: Effects Library Path Bug  (Read 2723 times)
Vladimir
« on: September 12, 2022, 10:40:37 am »
It looks like there is a problem with the display of effects list in the Effects Library when the username in the system has Cyrillic characters.
Example:
The library is located by default at C:\Users\Cyrillic UserName\AppData\Local\Itoo Software\Forest Pack Pro\effects. The list of effects is empty.
If you copy this folder, for example, to C:\Test\effects and replace the path to it in the HKEY_CURRENT_USER\Software\Itoo Software\Forest Pack Pro\EffectsDir\effects registry, then everything works as it should.
Tested in FP 7.4.3
« Last Edit: September 12, 2022, 10:49:08 am by Vladimir »
Re: Effects Library Path Bug
« Reply #1 on: September 12, 2022, 10:44:21 am »
Thanks for letting us know.
This came up recently as an issue so I'm happy to say it's already fixed in the Forest Pack 8 beta
https://forum.itoosoft.com/announcements/forest-pack-pro-8-0-0-beta/
Cheers,
Vladimir
« Reply #2 on: September 12, 2022, 10:50:14 am »
Exactly, in 8.0 everything is fine. Thanks Paul!
