Author Topic: Problem with transforming vertices and collision  (Read 4681 times)
Michael
« on: March 01, 2018, 01:30:08 pm »
I have a question,
When i activate collisions on my scattered trees bushes etc
the "transforming vertices" stages goes up from mere 10 seconds to 4 minutes.
I am talking about 3 forest pack pro objects with scattered evermotion trees and bushes, around 1m all of them.
I am using dual xeon 48 threads.
My forest packs dont have either animation on, or edges on area on, which i saw was the problem in other cases. My problem identifies when i turn on "collisions" on distribution panel.
Any workaround so that i get no collision but without so much time in each frame?
Thanks a lot
Re: Problem with transforming vertices and collision
« Reply #1 on: March 01, 2018, 05:18:51 pm »
In some cases, the Collisions feature might cause a significant performance hit on large distributions because of the very low efficiency of this method - all items need to be generated and later a huge amount of those might be discarded, which might take time & system resources.
Please feel free to send us a simplified scene to check it here. Thanks in advance.
I would suggest you switch from Generate to the Custom Edit mode - this way the "final positions calculation" will be made only while switching the mode and it'll be not necessary to perform it every time you start the rendering process.
