Author Topic: Version compatibility  (Read 3305 times)
RealViz
    • RealViz
« on: September 25, 2018, 09:45:16 am »
How about render version compatibility? If I use 6.1.2 for creating which version will render it properly (render node)? 6.1? Is there a rule for versions?
It is not always possible to upgrade to render stations in time.
Re: Version compatibility
« Reply #1 on: September 25, 2018, 09:54:55 am »
Hi, unfortunately there is not a fixed rule for that. Everything depends of the changes introduced between releases.
In this case, i think FP 6.1.1 should render without problems scenes created with 6.1.2, because the changes are only several bug fixes.
RealViz
    • RealViz
« Reply #2 on: September 25, 2018, 09:57:59 am »
OK, thanks.
