Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Final Gather Maps not working
« previous
next »
Print
Pages: [
1
Author
Topic: Final Gather Maps not working (Read 9257 times)
LE1050
Guest
on:
June 10, 2011, 09:53:46 am »
Im having a problem where I've precaluculated a Final Gather map on one machine and tried to render across a backburner network to reduce light flicker with my proxy trees. My problem is that some machines dont render any final gather at all? (see images below). This seems similar to an issue I was having with proxy objects not rendering on my render slaves that an Admin helped me with. (
http://www.itoosoft.com/forum/index.php?topic=798.0
Does anyone have any ideas? Could this be the same problem I was having before? I just need to narrow down if 3ds max is causing the problem or Forest Pro? (or me
and before you ask: everything is UNC file pathed
Im using 3ds max design 2011 (SP1)
Forest Pro 3.4.1
Last Edit: June 10, 2011, 10:27:17 am by LE1050
Logged
Administrator
Hero Member
Re: Final Gather Maps not working
Reply #1 on:
June 10, 2011, 12:35:44 pm »
It doesn't seem a Forest issue, because the Final Gather map is ignored completely. But i would try a render test removing the trees, to be sure that Forest is not the problem.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
