Author Topic: Forest Bend by Exclude Effect  (Read 5825 times)
Chris Fendryk
« on: September 11, 2017, 01:45:36 pm »
Hi lovely people of Itoo,
I've recently started working on neat system in forest but stumbled upon a glitch (I might be totally wrong).
Every time I create new forest surface (plane) the system works (every unit is fine), once I do exact same to a custom mesh it stops working (it takes only huge values)
and Im looking to use values between 20 and 50 cm max. Im not sure If I should attach file to the post or send it via email.
Could you guys give it a go?
Chris Fendryk
SSVFX
Re: Forest Bend by Exclude Effect
« Reply #1 on: September 11, 2017, 01:49:50 pm »
Hi Chris,
Please feel free to send us your scene and we'll check it here. Thanks in advance.
Chris Fendryk
« Reply #2 on: September 11, 2017, 01:53:53 pm »
Hi Michal,
that file is on the way to you!
Cheers,
Chris
« Reply #3 on: September 12, 2017, 11:59:44 am »
Hi Chris,
Thanks for the provided scene. With your help, we've ​​been able to reproduce such unwanted behaviour here and modified that effect slightly. Please find attached an improved version of such Effect ("BendByExcludeArea.eff") - to use it go to the Effects roll-out and Import the "BendByExcludeArea.eff" file - which shouldn't be facing this problem.
Chris Fendryk
« Reply #4 on: September 12, 2017, 12:29:40 pm »
Hi Michal.
That works like a charm, you guys rock!!!
Thanks a mill!
Chris
