Author Topic: ForrestIvy  (Read 14381 times)
JG_archviz
    • JG
ForrestIvy
« on: October 14, 2024, 08:41:42 am »
How you assign Object-Ids to forest. ivy "models"? You can't select forrest-custom objects like in Forrest Pack, also the models are not showing in "forest-templates".
I guess you need to assign an Object ID to Forrest Ivy just like with RailClone? And seperate different Parts of those Ivy-Models via Material-IDs?
Re: ForrestIvy
« Reply #1 on: October 14, 2024, 09:42:21 am »
For imported presets, used models are embedded. However, you can use the Extract Model to Scene button at any time to place a copy of the model into your scene, which can then be adjusted as needed. I hope this helps!
JG_archviz
    • JG
Re: ForrestIvy
« Reply #2 on: October 14, 2024, 10:10:07 am »
Ahh thank you - yes this might help in some situations.
So i guess the tech behind Forrest Ivy is comparable to Rail-Clone... as managing it is basically like in RailClone.
Its a great tool by the way to use now - specially to add various creepers other than with grow-fx.
