Author Topic: Forest objects will not render when using Xref object and corona  (Read 9972 times)
Arqrenderz
Hi, we are using max 2024, corona 11.2 and forest 8.2.6
No forest object is rendering when using xref object in the scene, already checked the renderability status, layers and so on..
Is this a known error or are we doing something wrong ?
RealViz
    • RealViz
Re: Forest objects will not render when using Xref object and corona
« Reply #1 on: August 06, 2024, 06:05:56 am »
It's hard to say what it is. We have little information. Does it render if the object is inserted directly into the scene (not xref)?. Is it simply a bad FP setting where the densities are too high?
« Reply #2 on: August 06, 2024, 08:08:17 am »
I'm sorry to hear, you're facing these troubles. If possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)). Thanks in advance.
