Author Topic: Forest Pack generated out of surface  (Read 3056 times)
TheMan
« on: June 05, 2019, 06:44:48 am »
This one just happen on my file today, yesterday was fine.
I generated new forest object and the forest is generated shifted to the left from the surface I chose.
The red plane is just freshly created from plane. The green one is plane and converted to poly and move the vertex.
There's another surface which is a roof. I tried before this surface to generate some grass on the roof, it didn't work. same problem.
Solution I tried :
- Reset X Form of the surface
- make new surface
- Saved and closed and reopen
- restart the whole pc.
none of them work.
Open new blank file and create new forest = no problem.
Temporary solution that work is to clone other forest and change the surface to the new one.
Merging into a new file might work, but I really want the cause and the solution of the problem so that I don't have to re-merge the file every time this happens.
Thank you.
Re: Forest Pack generated out of surface
« Reply #1 on: June 05, 2019, 08:09:25 am »
Hi please try following steps:
  • Delete forestpack object.
  • Reset xform on surface object.
  • Delete layer "forest_templates" in the layers manager.
Recreate ForestPack object. Hope that helps. If not please attach Your scene and we will check it.
