Author Topic: FOREST PACK IS NOT COMPATIBLE WITH CURRENT VRAY VERSION 3DS MAX 2023 + VRAY 5 UP  (Read 10739 times)
BR1671
3DS MAX 2023 + VRAY 5 UPDATE 2.3 (5.20.23 BUILD 00002) FOREST PACK 7.4.1
please help.
thank you
« Last Edit: May 25, 2022, 05:32:27 am by BR1671 »
Vladimir
Install the latest nightly 5.24 (31416) and everything will work as it should.
BR1671
where and how to get the nightly?
BR1671
thank you so much! but still doesnt work. is it working on your side?
Vladimir
Yes, it works great for me. What are your problems, what do you mean not compatible? Does it give any errors? Describe in more detail.
BR1671
yup here is the pop-up when beginning to render.
plus opening a 2022 max file crash 3ds max 2023
Vladimir
Are you using the latest FP 7.41?
Forest Pack is working fine here with the latest stable build, it could be an installation error that has left some unwanted files in the Max root directory. Please try the fix in the following thread to see if it helps.
https://forum.itoosoft.com/railclone-pro-(*)/railclone-5-2-2-instant-crash/msg33945/#msg33945
BR1671
thank you all. I clean install 3ds max 2023 and everything is working now. argh.
